How do I fix my dropping door?
Old 05-15-2008 | 10:33 AM
420WHP944's Avatar
420WHP944
Default How do I fix my dropping door?
Hi Guys,
I've been meaning to sort this problem out with my drivers door ever since I got my car...the bottom part of the door seems to ' kick out ' slightly everytime I opem my door causing it to rub on the bottom 6 inches or so against my front fender....I know its not the hinge that has sagged....I believe its a weld that has broke free from within the door that keeps the door skin held.....any body have this problem and more importantly know the best way to fix it?.....If I knew exactly where the weld was on the inside I was thinking of drilling a hole in the door from the outside and tack welding it back in place....grind off and repaint that section etc...
Hoping to hear of a solution!
Thanks guys
John.
Old 05-15-2008 | 12:03 PM
Ben951S's Avatar
Ben951S
pics? Previous damage?
Old 05-15-2008 | 01:52 PM
harrisonrick's Avatar
harrisonrick
Captain Obvious
panel adhesive (cheaper/lazy) or remove the door and reweld (better/proper)
Old 05-15-2008 | 02:09 PM
Burma Shave's Avatar
Burma Shave
Pics would help a bunch.
Old 05-15-2008 | 02:13 PM
theedge's Avatar
theedge
Take it to a shop. I tried to fix my drooping door.... Absolute nightmare to try to do.
If you do decide to attempt it, have at least one person to help you, they can hold the door while you fiddle with the bolts.
Old 05-15-2008 | 05:36 PM
420WHP944's Avatar
420WHP944
Thanks guys for the input so far...here are some pics of what I'm talking about...sorry if they are a little blurry but you get the idea..
In pic 1 the door is shut and all is well as regards its position...no problem there but in pic 2 you see how the bottom part of the door doesn't drop down but swings outward enough to rub off the front fender..
Old 05-15-2008 | 10:13 PM
Darwantae951's Avatar
Darwantae951
Thats the Passengers door!................
Old 05-15-2008 | 10:36 PM
420WHP944's Avatar
420WHP944
Drivers door....right hand drive car
Old 05-15-2008 | 11:04 PM
Darwantae951
I'm guessing my sarcasm wasn't detected...
Old 05-16-2008 | 12:58 PM
Burma Shave
Door needs to come off to repair (major pita due to wiring harness). Once it comes off the path forward will be clear.
Old 05-16-2008 | 01:49 PM
theedge's Avatar
theedge
Thats what my door was doing, and it was still doing it after I tried to fix it.
Trust me, I had more fun removing the engine or doing a clutch job than dicking with the door....
Old 05-16-2008 | 02:12 PM
harrisonrick
Captain Obvious
even lazier would be to add shims/washers under the bottom fender bolt to allow the door to slip under...
Old 05-16-2008 | 03:22 PM
420WHP944's Avatar
420WHP944
Thanks guys for the input....door off it is then - Now I know how I'll be spending my saturday morning!
Old 05-16-2008 | 04:45 PM
harrisonrick
Captain Obvious
After you remove the door just remember no sudden left turns if you're heading to the pub! LOL
Old 05-16-2008 | 05:40 PM
420WHP944's Avatar
420WHP944
Ah.....So you know about us Irish and our cultural activities then?!! Lol
Quick Reply: How do I fix my dropping door?
