Help - Dad is in trouble with his daughter!!!
I disassembled the torque tube on Kristy's 1987 944 turbo, expecting to install 4 new bearings that are on my shelf.
I found one badly mangled inner sleeve - not a good sign for our track day in Alabama on Wednesday!
Does anyone have either:
1) a spare delrin sleeve;
2) a good used sleeve; or
3) access to a lathe and the skill and time to make one?
I have a block of nylon that I believe is suitable for bushing material.
Of course this is worth $$$ to me!
Thanks,
Bob
Thanks,
Bob
I love the American work ethic - A machinist advertised his services on Craigslist.
He answered his work phone today @ 3 PM. I dropped the specs off @ 5 PM and he will call later today when the bushings are ready. He charges $70 / hr. and estimated less than 2 hrs to do the job.
Rainman
the inserts/sleeves? i believe some time ago there was a group buy on here for the delrin sleeves. im going to have mine made by a shop that i know well, the dimensions and specs are on clark's site if you want to take them to a shop.
these are the bearings you need.
http://www.vxb.com/page/bearings/PROD/Kit7373_1
BTW the C5 denotes the clearance. C5 means an extra loose clearance, C2 is the tightest. As there is no designation on the link it means they are of 'normal' clearance. OEM requires a clearance of C5.
Let me know if want to know any further tech details about bearings, I did a lot of research before I replaced mine.
Mike
You are correct, the originals are NSK 6006ZZC5. The RS designation in the link above denotes that the bearings have a single contact oil seal, the ZZ designation on the original bearings denotes that they have a double shield. Also the RS means they are not OEM as it is not a designation that NSK use, they are either SFK or ***. You are better with the OEM double shield (ZZ) than the single oil seal (RS).
Mike
Mike
I found similar info (re 928 TTs) here http://www.nichols.nu/tip799.htm
Sounds like they used bigger clearances on the 951 (v the 928) or they changed over time...?
Got them from the same place as the link above only ordered ZZ double shielded
http://www.vxb.com/page/bearings/PRO...FQsrswods1lHwA
They told me the clearance was C4 though it doesn't say that on the website. I have had no problems in over two years and am about to do the other car, a fun job (not) for the summer in FL![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I think some models used C4 and others C5, IMO I don't think it makes much of a difference as long as you are in the upper range of clearance.
I have a pdf document with all the specs for these bearings that I can email to anyone if they need it.
M
M
Resistance is Futile
M
M
Mind if I snag that .pdf from you? Thanks, Mike!
