Code reader?
So I've often thought it might be useful to have a code reader for my 944. Are they useful? Any point in getting one?
And also, is there a specific type I should be getting? How does this one look for example?
its available from 1988 onwards.
the 88 code system and readers are very basic but it improved loads by 1990.
http://www.jdsporsche.com/diagnostic%20FAQ.html
There is a socket in front of the fuse box area where you can plug in special tool 9246 and it will give flash codes if there is a problem. I have the tool which is also used to properly set the idle, but good luck finding one as I have never seen another one.
