How long do you let you S2/944 idle in the morning??
Old 05-18-2003, 03:59 AM
944S2NUT
944S2NUT's Avatar
Post How long do you let you S2/944 idle in the morning??
Just curious if you take off as soon as you turn the key? Or do you sit for 3-6 mins for a warmup then go?
Old 05-18-2003, 04:07 AM
triscadek
triscadek's Avatar
Post
When it's warm out, start it and go easy on it for 10 min. or so.
Old 05-18-2003, 04:30 AM
wjk_glynn
wjk_glynn's Avatar
Post
Porsche does not recommend letting the car idle.
The recommend procedure is to start the car, drive off and (as Paul said) take it easy until everything has warmed up.
Karl.
Old 05-18-2003, 04:45 AM
944S2NUT
944S2NUT's Avatar
Post
Ok great thanks for the info.
I hate warming up the car.
Old 05-18-2003, 06:10 AM
loonyjuice
loonyjuice's Avatar
Post
bear in mind it takes 3-4 times longer for your oil to warm up than for your water! My previous car had an oil temp. gauge and would need to be driven for about 5-10 miles before it would be at operating temperature!
Old 05-18-2003, 06:25 AM
Thom
Thom's Avatar
Post
I suppose Porsche do not recommend to let the car idle for too long as it damages the cat.
Old 05-18-2003, 12:22 PM
ziominix
ziominix's Avatar
Post
Considering when I get in the car in the morning I have about 10 minutes to get to school, a trip that usually takes 8 if traffic is good, I get in and go. I won't run it above 3 and a half or so until the engine temp is normal though.
Old 05-18-2003, 01:56 PM
Doug&Julie
Doug&Julie's Avatar
Post
Letting a car idle first thing isn't good for ANY car. If it's cold, let it idle for 15-20 seconds or so (to be sure the motor oil is moving and has gotten to all the parts), then drive away casually. The car must warm up as a whole, not just the motor. With casual driving, usually once the motor oil is warmed up, everything else is too.
Old 05-18-2003, 08:30 PM
Tremelune
Tremelune's Avatar
Post
Yup, definately drive real easy until the temp is up.
Old 05-18-2003, 08:33 PM
SidViscous
Big thirst, Sore Thumbs
Napoleon
SidViscous's Avatar
Post
And actually the car warms up much faster (oil and water) if your driving. Takes forever if your idling.
Old 05-18-2003, 08:52 PM
thedyingiraffe
thedyingiraffe's Avatar
Post
I just drive off normally until the oil temp reaches 2.5 to 3 bars. Then I shift at higher RPM.
Old 05-18-2003, 08:59 PM
adrial
adrial's Avatar
Post
I start it up, let it idle for 30 seconds to a min...and then drive off gently keeping it below 3000...then 3500 once the temp gauge is almost up to the normal region..then wait till the oil pressure drops to 3 bar at idle and have fun!
Old 05-18-2003, 10:29 PM
Fishey
Fishey's Avatar
Post
I start it up. Peel out take it 6500rpm's spin into 2nd then again to 6500 then to 3rd and so on... Untill 150mph! ........... LOL I am J/K
Old 05-19-2003, 02:05 PM
loonyjuice
loonyjuice's Avatar
Post
Unfortunately, I know a guy who does that! He has an new Audi TT and red lining from the word go is not uncommon when setting off from work. Also, he has been known to redline down the road pull into the car-park and switch the engine off, thus stopping all oil flow to the turbo, which is still spooling down from ~100k rpm! It won't be long before something expensive breaks.
Old 05-19-2003, 02:58 PM
Luis de Prat
Luis de Prat's Avatar
Post
Start and go (per the Owner's Manual).
When the oil pressure drops below 3 bar at idle, you can proceed to drive the car harder.
It's even more important to wait for the oil pressure to drop if the car is a turbo.
Quick Reply: How long do you let you S2/944 idle in the morning??
