Well this is a wierd one.
Big thirst, Sore Thumbs
Napoleon
Napoleon
Coming home from Boston tonight. The turn signal indicator would start flashing on it's own. I can re-create it by tapping the windshield washer or High beams, and sometimes it will stay blinking until I tap the high beams.
But the turn signals aren't flashing.
Don't say grounds, been there, done that.
Michelle, your cruise control brain is done and will head out Monday.
Relay? I had similar troubles on my '83, and my past '85. Relay on the new one, short in the harness under the dash in the old one.
In my current one there was also a wire that was fried, connected to the light switch. I removed that and my headlights started working properly again.
Sid - I sent you an email, don't know if you got it! Please let me know.
- Julie
- Julie
um, probably not your "grounds", but you might want to recheck your "f'ing grounds" lol
You might want to pull the turn signal stalk off the column and look it over. It might be a contact on the turn signal switch, or else a short on the wire harness for it. Its easy enough to pull apart and check.
Regards,
Regards,
Napoleon
Napoleon
Right, so I'll pull apart the harness. And the steering wheel, cuz I did futs with that to fix the washers.
Julie. Didn't get the mail, think I go an old one from you I'll reply too.
I've got a similar issue. If I'm in 'dimmer' mode, and use the left turn signal, headlights go off. If I'm in 'brights' mode, turn left signal, no problem. Except I'm on brights all the time, even when DIM. (are you still with me?) In other words, dim mode never works.
So brights on, headlights aimed low,is my temporary workaround.
Could MY problem actually be the wiring harness too? I've had the assembly out and looked at it, but haven't undone the rivets and really dug into it. If so, where exactly was the harness and relay problems on yours, Julie?
TIA
Goody
TIA
Goody
Could it be your hazard lights button sticking?
If not, since the actual blinkers don't blink, the instrument cluster board has a short on it - pull the cluster (you can do it w/o pulling the steering wheel of) and check it...
NOTE: 85.5 and later models only
Thanks.
Thanks.
I pulled the light switch out from the back and looked for a burned wire causing a short, and it was there. If you look in my thread on it, you will see it hanging until we fixed it last week. Had to wrestle the wire harness to see if there was anything else wrong, but it was only my headlight pop-up light motor, and we had to cut that wire out. Got another motor to put into it's place, and I'm going to have to rerun another wire into the harness so it will work again. Otherwise lights up for now.
Relays are above the fuses on my '83, and I suggest you go to <a href="http://www.clarks-garage.com" target="_blank">www.clarks-garage.com</a> to find the specific location.
Good luck!
- Julie
Good luck!
- Julie
