Clear headlight cover conversion kits available?
Old 12-18-2003, 03:24 PM
  #31
Chris_924s
Nerd Herder
Chris_924s's Avatar
Originally posted by Ben Z.
Do the covers require a compound angle, or would a simple bend be sufficent? Is tempered is a must-have? If not, it might be a relatively simple task to cut then put one bend in the glass (would require an appropriate glass, vicor or pyrex probably). I've done similar work using an oxygen/natural gas torch with silica glass and its surprising how shock resistant the stuff is; white hot straight into water is no problem. The rest of the details I have no idea about.
Personally, I think the ideal solution would be to just weld in some sheet metal then mount four 7 inchers on a roof bar.
Ben- I used to purchase fused silica in bulk for a laser manufacturer I once worked for. The raw materials for that size would be cost prohibitive. The light diffraction isnt that extreme due to the crystalline substructure of fused silica- but 1 piece the size of a headlight cover would be around a GRAND prior to working it IIRC.
There has GOT to be a better way..
Quick Reply: Clear headlight cover conversion kits available?
