Rear shock lower mounting point question
Hello,
I am replacing my rear shocks and have a concern. The way the shocks are installed right now, it seems there is too much space on either side of the lower shock mount, along the lower mounting bolt (see picture below).
Should there be a pair of washers or something next to either side of the lower shock attachment point?
Thank you!
Gary
Thank you!
Gary
I apparently cannot upload the picture right now.
Another way to phrase my question: if you install the rear shock onto the lower shock mounting bolt, are there any washers that need to go on the lower shock mounting bolt on either side of the shock?
BTW, this is on a 1986 951.
Thanks!
Gary
Thanks!
Gary
Hello,
Thank you!
Gary
Thank you!
Gary
Got it all figured out - there was a sleeve on the KYB shock as Riff pointed out. Got my Koni Yellows installed, looks exactly like Riff's picture.
Thanks for the responses; much appreciated!
Gary
Gary
