Power Perfect Users...?
Hey guys i'm trying to download the "MAFTuner Software" off Lindsey's site but having some difficulties
. Does anyone have a step by step tutorial on how to set this up? It's driving me nuts...no punn intended. This is what's happening...I've open up the program using "Winzip" as directed, but i'm missing the step on creating the "MAF TUNER" directory. Which i'm sure needs to be created before I can load the provided fuel maps as a base starting fuel map. How do you set up the "MAF TUNER" directory? Appreciate any advice/help you can share...THANKS
If you link to the software some one really bored might download it and then explain the procedure for extracting it.
Easiest way is to...
Right click the downloaded file, and there should be an option (depending on how you installed winzip) to 'Extract to: ////// ' (and you can pick where to extract it)
Are you guys happy with the perfect power product?
I had one of the previous models on a BMW and it gave me endless problems losing its memory resulting in failure to start the car.
Sorry for hi-jacking, just thought it fit under heading.
