Late manual tie rods power to manual steering SOLUTION
#31
It is essentially the exact same as an early tie rod end.
I needed something to thread into the inner rod atleast 3 inches and then make up ~2" before threading into the outer.
If you could find out how long the threaded section of that tie rod end you posted is, I would be interested. But in honesty, I think the set-up I have now (calculations wise) is much stronger than if I did simply find a longer threaded tie rod end unless I could find a sleeve or something.
Hopefully this answers your question?
#32
Two of them are a little cheaper than the $40 threaded rod plus new later style ends.
#33
Blah, blah, blah. Trying to confuse me with the facts, eh? Your car has too many cylinders. And what makes you so special that you don't have to worry about a cam belt breaking? Because you can swap water pumps in 20 minutes somehow makes you special? I'll bet that LT-1 isn't all gravy. I heard you have to wear a mullet in order for the thing to start. You really are missing the point of the stock engine. The point man, the point!
I haven't driven one of these cars, nor do I have direct experience, but that doesn't mean you know more about it than me! And don't get me started on that crappy LS series of engines. I don't know anything about them, but they don't compare in any way to a Toyota mill.
I prefer factory solutions. That way when someone walks by when my hood is up, they see "Porsche" on the cam cover, and they know, I own a Porsche. Because what people think is most important.
Also, your car is dangerous. I had a real life race car driver tell me so.
#36
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
![order](https://rennlist.com/forums/graemlins/order.gif)
Now, cue the "the car wasnt meant for speed" crap and the always plesant small wee wee jokes. I have a bigger engine so I am not well endowed. Thats entertainment
#37
Almost Addicted
944-LT1, can you change the thread title to "Late manual tie rods power to manual steering SOLUTION and why you should get a chevy v8 and stick it in your car"?
Jus sayin... you guys are show offs! DVC, you know how much I admire your car, and 944-LT1 I have a couple questions I'm going to PM you with.
Great work, both of you.
#39
It is time I resort to barraging you with a flurry of homosexual insults. After that I'm going to photoshop you and your car. It won't be flattering nor will it be all that funny.
Don't you people have your own forum some where? What's really funny is that you need all that displacement to make any power. rolf....
But first, I'm going to let you know that it would have been acceptable had you used an import motor. Something like a VR3G0789, or perhaps an HG-3051RBA. No, they are not proven and probably won't work, but that's what I'd use. Yours has too many cylinders and you missed the point of the stock engine. In fact, I'd rather get ran over by a bulldozer than swap a V8!
(P.S. The only reason I PM'd you, is because I don't want anybody else to know I dig your car. I expect I'll have your reply regarding the swap details by tonight.)
#41
I perceive your use of a V8 as a direct indication of the inadequacy of my stock engine. And for that I RESENT you!
![](http://www.porschehybrids.com/albums/944-LT1/vette_2.sized.jpg)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I am starting to get the feeling that Im taking part in something I dont know anything about....
