Late manual tie rods power to manual steering SOLUTION
944-LT1,
Can you give me more info on the Engine swap parts
and "the other board "
hboehm@wilkes.net
hboehm@wilkes.net
Both the bellhousing news and the front crossmember news are fantastic. I have the utmost respect for the "r&d" you guys do with these cars! For now I'm obsessed with going with a turbo conversion instead of a v8, but if I ever change my mind I know exactly where I will be visiting.
Excellent article and a great find.
I just placed a order with McMaster-Carr for the threaded rod.
I have a couple of track car projects.
Thank-you!
Thank-you!
It sounds like a sound solution, but I would dismiss it based upon the fact that this guy put a Cheby in his Porch! Why don't you just buy a Corvette? Sure, it will be heavier, not as good looking, a dime a dozen, and smell like a boat, but......well, I can't think of anything else to say. Oh yes I can, why don't you just get a 928? Aren't you missing the point of the stock engine?
No, I have never driven a 944 V8, but when have you ever needed experience for your opinion to matter? Besides, ranting over your car makes me feel less inadequate about my own. And finally, it really burns me to see that you actually enjoy your conversion!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Who makes Porsches anyway?
Brakes by Brembo & ATE, Seats by Recarro, Instruments by VDO,
Electrics by Bosche, Carburetors by Weber & Solex, Turbochargers by
KKK, Shocks & Struts by Bilstein, Koni & Boge, Synchronisers by Borg-
Warner, Wheels by Fuches, Bodies by Barth & Karmann… Need I go on?
I wonder if Porsche manufacturers anything for their cars?
Are the Porsches you see at the races "pure" Porsches?
Are their engines, chassis, suspension, etc. what you can buy at the
Porsche store?
Tell me about the upgrades made to all racing Porsches, including
factory cars? Fiberglass or Carbon-fiber body parts, Suspension upgrades, Steering wheels, Seat belts, Roll cages, Wheels and tires, Lexan windows, etc.
etc.
What makes you think your "recipe" is "correct"?
Why can't my "recipe" be just as "correct"?
Does a Porsche have to remain just like it was manufactured?
Why didn't the manufacturer (designer & assembler, if you will) let
the car remain just like it was manufactured, I mean assembled,
instead of changing it every year? Yes, planned obsolescence was a
big reason, but didn't they improve it too?
Therefore, isn't my improvement approved by the manufacturer, I mean
designer & assembler? I haven't heard from Porsche on this matter!
Only people like you.
Any concerns on the tensile/shear strength of the threaded material? I applaud the ingenuity on your solution, and just want to make sure there's no concerns re load bearing stresses. Is there enough room in there to make the threaded piece a bit longer? 1" seems like it could be a bit short to me.
No flames from me on the conversion, even tho I tend towards admiring factory solutions. I'm also somewhat of an old school rodder and harley rider, so I have modified all manner of vehicles.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Regards,
Regards,
I reread the original post and I have no idea where I came up with 1" either. Time to switch to decaf, I guess! lol
Regards,
Regards,
This also works:
http://www.allzim.com/acatalog/Tie_R...1_912_914.html
Two of them are a little cheaper than the $40 threaded rod plus new later style ends.
So it would need to be whatever the stock early tie rod length was plus ~3". More the better really.
The joint itself is identical. I don't see what you are talking about when you say:
"I needed something to thread into the inner rod atleast 3 inches and then make up ~2" before threading into the outer."
It is essentially the exact same as an early tie rod end. You don't have to thread it into anything except the inner rod.
-Darwin
-Darwin
