I need to know Oil, struts,shocks and a few other questions 87 944 n/a
#1 do a search on timing belts. hope you are sitting.
#2 15W 40, dont go thinner than 40. any brand you are OK with. I use mobil 1. better filter brands.
#3 &4 if you need shocks you are in for a $$ surprise. look up the post i started/bumped. a fellow on this board has the struts out of my 89 S2 with 69k miles. you can get all 4 shocks/struts/&front springs ready to install for less than 150. then you can sell your old fronts to paragon for the same 150.
otherwise your choice is koni inserts, and the parts cost about 600.
