Ebrake Cable Replacement
Who has done this?
I started knowing that mine did not engage and did not catch even if i adjusted them at the rotor. Upon the further inpspection the long cable is snapped. I undid the bar that holds the cables underneath the car but can't get them out from there because it looks as though they run though brackets that are welded on
How do I get them out?
Figured it out. Remove little clips, expose cable, slide out small slit in bracket. Easy as pie.
New question: How do I route the new cable into the car? Do I need to bondo around it or something when it's done?
