Door handle is broke
Old 03-11-2008, 11:10 PM
potent951turbo
iPod Tamer
potent951turbo's Avatar
Clarks Garage has a writeup on removing the handles. I never have been able to put the handle back on without removing the door panel and taking out the rear window track(which is very simple). It will save you a lot of misery to remove the panel IMO.
Old 03-16-2008, 01:30 PM
Paul C 944
Paul C 944's Avatar
Anyone got a write up on taking off the door handle and dogleg? I got the door panel off still dont see what broke.It looks likw a PIA to get at too. Any help /tips on removal are appriciated.
Old 03-16-2008, 01:40 PM
potent951turbo
iPod Tamer
Go to www.clarks-garage.com and it will have info on removing the handle.
Old 03-16-2008, 01:41 PM
Luis de Prat
Luis de Prat's Avatar
Hi Paul,
It's pretty well explained in http://www.clarks-garage.com. If you have Haynes manual, it's also explained with photos.
Once you get the handle off, you will see what's broken and how to replace the linkage. If you get stuck, post a few pics of what you've got so we can help you better.
Old 03-16-2008, 01:54 PM
Paul C 944
Paul C 944's Avatar
So far it looks like the white metal part ,the pin is in place and platic is not broken,i just cant see inside to tell if metal part is broke.Ill look again,and review the clarks link.Haynes wast much help.Poor pics
Im looking at this for detail pics.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=ADME
:B:EF:MOTORS:1123
Thanks guys!
Old 03-16-2008, 02:04 PM
Paul C 944
Paul C 944's Avatar
Ok I got it apart with clarks help.the white metal part was busted.So At least is a a cheap part ,still I think it will be a pain to get working again,we shall see,ill see if dealer has the part,if not off to ebay.
Old 03-16-2008, 02:09 PM
potent951turbo
iPod Tamer
When you go to put the handle back on, it is easiest to do it with the door panel off. There is a black metal cover/plate that covers up most of the handle that is attached with 3 8mm bolts. If you remove those the plate will be out of your way and you can access the handle more from inside the door. You may also have to remove the rear window track which is held in place by that plate and also another 8mm bolt at the bottom of the track. I don't think any of that is explained on clarks-garage but it is very handy.
Old 03-22-2008, 12:13 AM
Paul C 944
Paul C 944's Avatar
New help needed
Now the door handle it self is broke! Ugh,Does anyone have a spare handle,drivers side for a 85.5 944?
The little tab that the tension pin pivots was also fatigued,1st shut of the door the piece broke,another week to find and get parts.
If any one has a part please post and or pm.It would be great if someone local has a handle i could pick up.But ANYONE please pm me I want to finish up this repair!
Thanks,
Old 05-19-2008, 10:53 AM
namespace
namespace's Avatar
Originally Posted by potent951turbo86
Okay I found a picture of the part on Pelican Parts. The last couple of handles I have seen break, it was the triangular pivot piece on the end of the rod. To repair it all you have to do is remove the handle from the door and remove the tension pin that it pivots on and put the new part in.
I bought this linkage to repair my drivers side (RHD) handle - Early 944.
Pelican description says 85.5 onward, but it fits an early just fine. The only differences I could see was the hole for the roll pin (which mine came out easily) is a different size on one side of the new linkage.
A simple matter of enlarging the hole ever so slightly, so the roll pin can slide in nice and snug.
installed and tested OK. Now I don't have to open my door from the passenger side or leave my window down for ease of interior door handle access on drivers side. Happy Chappy.
Quick Reply: Door handle is broke
