early 944 manual rack tie rods - 00 vs. 01 the same ??
1 Post
I've been trying to get replacement tie rods for an early chassis 83 944.
It's a manual rack, and everyplace (even Porsche) seems to be backordered on the "00" part number. 944-347-033-00
Is the part 944-347-033-01 the same ??
Does anyone have any ???
Don
Don
944 347 033 01 Is the part listed in both my supplier cat's here at the shop. Same for L and R sides. My cost is around 100.00 per side.
It's a TRW part, not Lemforder. Only have (1) Lemforder avail
Almost Addicted
The newer tie rods are significantly longer to accommodate the late offset- I just switched my rack out for a manual and had to swap in the late tie rods, they are not even close in length. You may need to change other components to run the late offset tie rods.
he has an early offset car so the part numbers mentioned above will be fine. Alex you are correct if it were a later offset car, of course you already knew that, LOL.
Almost Addicted
