Tranny Crunch!
Tranny Crunch!
When shifting gears and sometimes when driving steadily and pushing in the clutch there is a "crunch" sound that i believe sounds like it is coming from the transaxle. I've had this problem ever since I bought it a year and a half ago. Anybody think they know what it is, and if it is fine being unreplaced? Thanks!
The noise is more of a crunch rather than a clank i would say, and it does it when shifting, and sometimes when the clutch pedal is pressed. Also when i am going very slow in first gear through a parking lot or something it sometimes does it then too. Its like a crunch crunch crunch. My buddy said its the throw out, is this possible?
The noise only occurs when pressing in the clutch or shifting. For example, if i were driving and pushed in the clutch to coast, then while the clutch was depressed i shifted, the crunching noise would be made when i initally pushed in the clutch then stop, then when i shifted gears then stop again. It seems like it is only when i use the transmission. As far as it being a cv shaft i dont understand why this noise would be made. I know it should probably be replaced but ive had it for a while now and nothings gone wrong, although i know with these cars sooner or later something will go wrong
