Spark Plug Question
What is the difference between NGK BPR7ES and the NGK BPR6ES?
Called a shop and they said I need BPR6ES plugs. I think my car has BPR7ES. I know Amazon.com is not an expert but it says the BPR7ES won't fit.
It's just a difference in the heat range. If I'm not mistaken, the the higer number (BPR7ES) is one increment hotter. All this means is that the center electrode is extended just a bit further out than the cooler plug, so the center electrode stays at a slightly hotter temperature during normal running conditions. Going +/- one heat range from spec won't make that much difference.
I have a buddy that raced a little 125cc 2 stroke race bike years ago; he used to swap plugs and carb jets for the weather conditions. Typically, when he set it up to run a bit richer, he'd go one or two heat ranges hotter on the plug to keep it from fouling. Conversly, when running leaner, you reduce the heat range of the plug to reduce pre-ignition (knocking).
This is wrong . With NGK spark plugs , the lower the # the HOTTER the plug . It is also this way with ND spark plugs . The japanese plugs are opposite the american plugs as with Champion / Autolight ect , in which the higher the # the hotter the plug . You are right , with high boost / compresion u would want a colder plug ( the 7es )
That being said , i would always run a cool a plug as possable . Why do you think your running rich ? Have you had it on a gas analizer or wide band o2 sensor ? 14.2 to 1 is optimal , but better hoarsepower figures are obtained at a slightly rich 12.5 to 1 fuel toair mixture ratio ..........
