starting problem 83' 944
Turn key on (nothing) off... on (nothing) off.... on (PURRRRRR)
Starts right up!
Is a random start issue like this a....Starter? Cable? Relay?
EDIT: New problem! EDIT
I took the starter apart and it was filthy and the brushes, etc were covered in corrosion. Cleaned it all up and my car started great for a few weeks.
Ordered a new starter right away and it just got here today. Installed it and the starter would turn but wouldn't engage with the flywheel. Took it back off and had it tested at a local parts store (saw the teeth move forward as they would to engage the flywheel in the tester) Back at home, checked voltage at the battery, at the end of the starter cable, and at the end of the switched starter cable while someone tried to start the car. Checked for continuity across all the fuse and replaced a few that were looking old. Searched for info on a related relay: found none???
Finally decided to try "jumping" the starter, connected a wire to the main terminal on the back of the solenoid. Reconnected the battery and reached under (car on jack stands) and touched the wire directly to the switched terminal.
Same as before, starter turns but makes no attempt to engage w/ the flywheel....even though I saw it do it on the tester....
I'm at a loss and I'm leaving it alone for the night... Hopefully someone has an idea?
Starts right up!
Could be a couple of things. From what you describe that there is a humming sound when you turn the key, but the starter doesn't engage, it sounds like the starter solenoid is sticking. You will need to remove the starter, disassemble the starter solenoid, and relube it. It probably is all dried out and sticks when trying to engage.
The other source of your problem could be from a ignition switch going bad.
I would check those battery cable connections. Could be something simple like that.
Could the constant humming noise be the ventilation fan? Don't think it would be the fuel pump but that may be a possiblity although I thought the pump was not constant on with the key on.
DME or Relay? Ignition switch?
Just throwing things out.
How long does the solenoid fix usually last?
Guess I better check some more things out tomorrow..
Forgot to add. I thought perhaps my mulitmeter is inaccurate the battery isn't supplying enough voltage to engage the flywheel. So I tried jumpstarting the car w/ the same results. Starter just spins..
You have the wrong starter.
Case is def. the same, teeth are the same, plastic cap on the solenoid was slightly different shape... but.... I did go take it back and they're going to send me an Autolite one (that's actually cheaper than the no-name brand starter they sold me before.
I believe i had the same problem a few weeks ago. Turn the key and get nothing except an ominous humming sound. Battery was charged and is good and everything worked as it should other than the fact the starter did not engage. No click, no anything. I had the problem once before, tapped on the starter and it fired right up. Same happened again a few weeks later, tapped on starter and nothing. Tapped harder..still nothing. The hum was not the starter spinning, so the solenoid was not the problem..im guessing it was the fuel pump.
I wasted an entire day testing everything. I checked all wiring, battery cables and tested the starter off the car. Everything worked as it should. I tested the ignition switch as per the directions on ClarksGarage and it tested fine also. I replaced it for good measure (PITA)..and the car starts fine again. Im not sure exactly what the problem was as there was nothing that tested bad. I have a feeling it was an intermittent failure with the ignition switch as they are known to go bad and mine was original (had 928 part #, new ones are superseded to 964 part #) with a little over 100k miles on it.
Also not all rebuilt starters come with new solenoids.
