Porsche 968 Crank Trigger
What style crank trigger does the 968 use? As far as I know, its not the same setup the 944 uses.
I've heard its a motronic 60-1, but I am looking for confirmation.
thanks,
Adrial
thanks,
Adrial
The cam sensor is generally needed to distinguish an intake cycle from a combustion cycle, so that fuel is only delivered when it's needed (sequential fuel injection) instead of every cycle (batch fire).
the 60-2 crank signal is generated every 360 degrees, the engine cycle is 720 so the CPU needs the cam trigger to know exactly where it is in the engine cycle otherwise it doent know if its top of exhaust stroke or compression stroke TDC. Your right that this camshaft sensor is used for sequential injection and spark/knock control.
I thought the variocam was a RPM driven function, so it would need some smarts to look at rpm then generate a digital on/off signal that would be via the CPU, which could derive rpm from either the crank or cam sensors.
