Timing belt comes off the gear on the end, unscrew the bolts inside the housing through the little ports. Those are the challenging bits. The rest is self explanatory.
Reason: I would also advise you mark the cam gear on the gear to make it a little easier to time the motor when its.....time
Not really, just put a blob of grease on the end of your allen key and with a steady hand they come out without a hitch.
The grease will hold a vacuum between the key and the bolt head, effectively sticking it to the key, as long as you push it in all the way.
