Bad 968 Fuel Pump... Again...
92' 968... 3 years ago, I replaced my bad fuel pump, fuel filter w/ check valve, fuel pressure regulator...
Looks like I'm gonna have to do the same thing again... Pump removed and just "thuds" with 12vdc applied...
I read where "Fuel Pumps are very reliable and it's usually something else that causes failure"...
What else is there?
As luck would have it, and now that I have a Full Tank, the only thing left is the Tank Strainer... I guess a slightly restricted fuel flow could ruin a fuel pump?
What else is there?
What else is there?
What else is there?
Nerd Herder
Damn Moe. Stop feeding it crap fuel.. LOL
I've had 3 bad fuel pumps in a row (True, they were for a 98 Taurus) nontheless. Bad rebuilt --(even new) Fuel pumps do exist.
Moe,
Welcome to the club. I'm replacing the fuel pump on my racer that was installed (new) last April, which replaced a 6 mos old pump that quit on the track at Mid-Ohio. I'm hoping "3's the charm" and this latest pump will at least last a full race season.
Given the chronicity of my problem, it could be something other than the fuel pump, and if the pump we replace appears to be okay (I'm still replacing the part), you're welcomed to it - of course, I won't send it to you if I suspect it's failed or defective.
Ciao.
Ciao.
Moe,
Ciao.
Ciao.
If your pump is good, let me know what you want for it... I was gonna make a Pelican order later today... Heck, you may wanna hang on to it...
Thanks...
Moe,
Ciao.
Ciao.
Moe,
I won't know anything until sometime next week. Some of the parts (e.g., fuel pressure reg), arrived this week, we're still waiting for the fuel pump.
I really don't know what to ask for a used fuel pump. If you still need the part when we finally get around to removing it from my car (next week, hopefully), I'll p.m. you.
Prof,
Car dyno'd at 221 RWHP last June. The plan is to dyno the car again next week before and after the fuel system repair.
Prof,
