Gutting Interior - Advice Please
Hi all --
I have an 86 944NA that I have been tracking and, this year, will be racing in 944 Cup. The car has a cage and racing seats with harnesses. I've done about as much as I can with the suspension and can't do much with the motor, so the next step is to put the car on a diet. My shop will handle things like deleting the AC and pruning the wiring harness, and they will gut the doors when they add the second door bar. But I want to do as much of the interior work as possible myself. Unfortunately, I'm completely inexperienced. So here are some (presumably stupid) questions:
One of the things I love about this hobby is that I am learning so much. However, mistakes can be expensive as well as embarrassing so I'd appreciate any advice.
Thanks in advance,
Ron
- I'm guessing that the first step in all of this is to remove the seats and harnesses. Is there a way to do the interior with the front seats in place?
- How exactly does the rear seat come out? Is it one piece, like it looks, or several?
- What temp do I use on the heat gun to melt the gunk but not toast the car?
- What obvious questions am I forgetting to ask?
Thanks in advance,
Ron
-----You can, but the seats come out easily and help you get most of the junk out.
--------Top part is bolted in and bottom is just glued in. - What temp do I use on the heat gun to melt the gunk but not toast the car?
-----I never used a heat gun. I scrapped what I could and left the rest. Chemicals alos work. - What obvious questions am I forgetting to ask?
-----Are you pulling the dash too?
Good luck with the glue!!! I had 40 hours into my interior "gunk" strip but I was prepping for a interior re paint so I had to get everything off and clean. I tried everything, wire wheels, goop off, heat gun ect. The best product was the 3M adhesive remover. It worked wonders and would have saved hours if I started with that first. Buy a gallon, you will probaly need it.
Check out Genikz (Chris') spec build out site http://www.brooksbabies.com/porsche/. I plan on referencing it for mine. Good luck. Michael
took me and friend a ton of hours to get the glue off. but check out ace hardware. they have this paint and stain stripper. it comes in a box can and it's a gel. get a couple of industrial grade wire mesh scrubbers. maybe even some steel wool. a heavy duty work glove. and a big fan to keep the fumes from knocking you out.
after we cleaned out all the gunk, my friend rhinolined the interior. now it's nice and durable
Here's a DIY for removing the rear seat.
https://rennlist.com/forums/diy-924-931-944-951-968/216274-weight-reduction-project-rear-seat-delete.html
