How do you adjust the pop-up headlights?
Had to remove the headlight motor today in order to check and patch up the headlight wiring on the passenger side.
Put everything back together and now my headlight buckets are not rising all the way up and have some slack.
How do you adjust the height of the pop-up headlights? TIA
take the braket that attaches to the motor off- 13mm nut- turn the headlights on so they go up, push the lights up all the way, then reattach the braket and put the nut back on. Then turn the lights off. If the lights go back perfect then great, if they are up/down alittle there are two bolts that hold the pivots to the frame rails- 10mm bolts- loosen those alittle and push them forward/back until the lights are correct.
