Still no heat!
OK.............. So I just went to Autozone and got the pressure tester. I hooked it up and got not a single air bubble!!!! By this point I was fuming mad. I then went to figure out exactly where the heater core hoses run. Guess what I found??????? The PO had the heater bypassed!!!!!! I found the two loose hoses tucked down by the firewall. When the car cools I'm going to hook them up. I'm hoping that the PO was getting too much heat, and just had it bypassed. I already found the broken clip that would have made a full heat situation if the heater were hooked up. Hopefully thats the only problem. I'll let you know in a few hours.
Anytime Jon. Just remind me when local events are and I'll come by.
So I just reconnected the heater.... I have heat!! No other problems surfaced. It does seem that the PO had the heat disconnected all because of the clip under the dash.
Thanks everyone!
Thanks everyone!
