944 NA tow point
alisontaur (10-02-2023)
Hates Family Guy
There's a couple tie down points that are fairly obvious when you look under the front of the car, you can carefully pull on one of those. The problem is they are higher than the bottom of the valence and if he has to pull hard it will flex the valence and possibly crack the paint. There's a couple other things you can do, if he has the right sort of hook you can use the hole in the bottom of the bumper where it attaches to the bumper shock and pull on that, but don't tie it down with that. Or remove the bumper and pull from a bumper shock.
I had to tow the early car a mile or so when the refrence sensor failed - I poped the hood and tied on to the strut brace.
If you just have to pull it up onto the flat bed, you could probabaly even use the rear engine lift hoop.
