do wheel center caps have holes?
the allen was not to pop the caps off, it was to prevent teh caps from being removed unless the wheel was off the car, and you unscrewed the allen head screws that went from the center of the wheel outward.
The allen key ring is on the back of the cap to hold them to the wheel securely. I think they are an aftermarket idea and not from the factory. They fit Cookie Cutters or Fuchs center caps only.
![](http://www.automotion.com/aux_incl/images.ashx?i=ID+106817_1.jpg&partNo=106817&w=600&h=600)
The tool to remove the center caps with holes (some has them, some didn't) can be made with a bent aluminum coathanger
![](http://home.comcast.net/~srosenzweig/Removal_tool.jpg)
You can buy both at Performance Products
