Grounds
you should try cleaning your grounds
I don't think one exists, but if you go on dcauto.com you can find parts diagrams that show a little bit of how the wiring harnesses are set up.
Canadian Yankee
There is a diagram of all the ground locations. I have a copy of it. I got it from work, it should be in one of factory service manuals I believe.
If you lay upside down under the drivers side of the dash you'll find two that are easy to get to and a few that are more difficult. There is one under the rear carpet around the center/rear of the hatch. One for each head light just behind them and the main ground near the back of the engine.
+1 Keith, like to add that there are two grounds at the back of the engine, main and dme. These get gunked up bad, especially if the car has ever suffered a leak from the heater control valve. Also the wiper motor has one strapped to the case.
A good pic of the "easy" grounds Keith mentioned:
This is from elsewhere on rennlist
Canadian Yankee
