Will the 87 951 fronts fit on my 88 NA?
Yes and no. They will fit if you get the spindles and hubs and brakes with them
The turbo has a narrower slot where it fits into the spindle. You can use an NA strut on a turbo if you fab a proper 2mm shim - still dicey. You can not bolt an NA spindle right up to a turbo strut.
This is all well documented. Search.
