944 Steering Wheel
Old Nov 11, 2007 | 04:10 PM
Po924S's Avatar
Po924S
Default 944 Steering Wheel
I just bought a four spoke steering wheel from a 1987 944 Na. This will fit my 924S, right?
Old Nov 11, 2007 | 04:29 PM
xsboost90's Avatar
xsboost90
hmmm. you may want to compare the length of the "pin" sticking out on the back of the wheel- i think the early style was alittle shorter than the later style and if you bolt it on you can short out your turnsig switch and burn up some wiring- ask me how i know. That being said i think you can swap the backing w/ the pin on it from wheel to wheel.
Old Nov 11, 2007 | 05:35 PM
athens944's Avatar
athens944
Dan is correct. Just remove the backing from the older wheel and you should be ok.
Old Nov 11, 2007 | 07:56 PM
Po924S's Avatar
Po924S
Thanks guys, I'm excitited about my new steering wheel! Do any of you guys know where a shifter like this?
http://www.theexitwound.com/944/shiftbootinstall12.jpg
I don't just need the leather part, I need the whole **** and such. Thanks.
Old Nov 11, 2007 | 08:16 PM
TNT25169's Avatar
TNT25169
I have several without the leather, just the **** part. You could always recover it. Feel free to email me at APartAbove@aol.com
Old Nov 11, 2007 | 08:19 PM
Chris_924s's Avatar
Chris_924s
Nerd Herder
You also may need to swap the hub- there are different offsets as well.
Old Nov 11, 2007 | 08:42 PM
Po924S's Avatar
Po924S
Would one like this work? Then I just need to buy the shift know inserts, correct?
http://item.express.ebay.com/Shift-B...mdZExpressItem
