Rough Idle 84
My 84 starts fine when cold. After a few minutes the idle dips to about 400 rpm, the car sputters for a while then shuts off. If I give it a little gas to keep the revs up it is fine. Speed sensors? Fuel pressure regulator? Any ideas?
Not Special
Could be the Auxiliary Air Valve.
http://www.vertexauto.com/ShowItem/3...r%20Valve.aspx
See https://rennlist.com/forums/showpost...3&postcount=34 as well.
