Help With Compression Test
I will be doing one tomorrow morning and I cannot find what the acceptable results would be! Can someone tell me what range I should be within?
thanks
can someone PLEASE give me a link to the clarks garage article on compression tests?
thanks
I gained about 15psi when the engine is warmed up and the throttle opened full, which is how you wish to do the test anyways.....
Don't be surprised with low number on a cold engine and closed throttle body.
Here's the link but the site seems to bee down at the moment. (I was on iy just a few days ago)...
http://clarks-garage.com/
The factory wear limit is 145psi at sea level. Anything north of 160psi is good.
Hope that helps...
~Clint
oops...I think that is for '87+ cars for some reason. Maybe someone can confirm that?
Hope that helps...
~Clint
