'95 968 Vacuum Booster removal
Please do not tell me you have to remove the intake manifold to get this thing out.
Is it possible to disconnect the rod and clevis on the booster end from the inside and sneak this booster out of the vehicle? I already removed the clip and pivot bolt thing at the pedal end.
I sure hope there is a way to remove this thing without taling all kinds of crap apart. Right now it is unbolted with the vacuum lines and master cylinder off of it.
I moved all hoses and wiring out of the way the best I could. I can roll it around a bit, but I suspect the rod is limiting its removal.
Thanks,
Mike
Thanks,
Mike
968 Brake booster removal
It sounds like this failure ight be a common occurance as these cars age,,,bummer.
By the way, I am still clueless if I can get the booster out of the way without removing the intake manifold. If you catch wind of any info one way or the other, please let me know.
