How much oil does a turbo burn?
Old 10-05-2007 | 01:04 PM
black944 turbo's Avatar
black944 turbo
If I held it there long enough, I am sure it would. The car still only burns about 1/4 (max) quart every 3000 miles.
Old 10-05-2007 | 01:15 PM
Luis de Prat's Avatar
Luis de Prat
Originally Posted by xsboost90
my n/a used more oil than my turbo- it used one quart in a two day track weekend.
Assuming comparable miles, engine condition, etc., obviously.
My 944S2 with 150K miles uses practically zero oil between changes, whereas the 951 with 67K uses a bit more but nothing major.
Old 10-05-2007 | 10:50 PM
Jake951's Avatar
Jake951
Oil consumption varies with the type of driving you do and the oil viscosity. Consumption is greater with lighter weight oils. For example, with Mobil 1 5W30 (winter weight oil), I go through about 1 quart per 1000 mi. With 15W50 (summer weight) it's 1 quart per 2000 to 3000 miles.
Quick Reply: How much oil does a turbo burn?
