Is my muffler backwards
I had a tailpipe welded onto a muffler and I was about to put it on the catback pipe.
I look at it and is says "Inlet" with an arrow below it pointing towards where the tailpipe was welded on.
If the arrow indicates flow direction then it is welded correctly, but if the arrow is actually pointing to the inlet then it's backwards.
Which way is right? It would make sense that the arrow goes in the direction of flow... but it has inlet written above it.
If it says inlet and an arrow then it's talking about the inlet. If it was an arrow with nothing else I would assume flow. If it said flow and had an arrow I would say the arrow was the direction of flow. You're assuming the arrow represents flow from other examples. It's the inlet.
It was pretty clear that it was on backwards. I called the dude got an "oops".
Luckily my dad is a welder and he cut it and flipped it for me.
The muffler is just some dumb midas brand ravin shiz. Doesn't sound raspy so I'm fine with it.
1 Post
this is hilarious, ive never heard of that happening. luckily it all worked out for ya
fast924S- nice to see another '87 924S. your signature says "currently being rebuilt for more power" what are you doing?
LOL Kinda OT But, Yea not many of the 924S around anymore. Well I have been slowly working on her for about 3 years, Took it off the road cuz the clutch was sliping and I decided to pull the whole motor and do a performance rebuild. It took a while to save up the funding cuz I learned that take what you think you will spend then triple it LOL. Im about 80% done with the motor. List of motor mods done so far.
1. Balanced bottom end
2. cross drill 2&3
3. shot peaned rods
4. went to 88 10.2CR pistons
5. spec Lightweight flywheel
6. Full engine rebuild (bearings/rings/seals ect..)
7. A/c delete
8. Port matched head, valve seat work,5 angle valve job
9. Port matched and worked t-body
10. Huntley Racing stage 2 MAF kit
11. Bursche Header and test pipe Heat wraped
12. AFPR
13. Innovate wide band 02
14. Lindsey Racing oil pan baffel
15. ARP connecting rod bolts and head studs
16. Lindsay RAcing Adjustable cam gear
17. B&B catback exhaust
Things needed for engine,
1. New Rad.
2. Jme cam
3. spec stage 2 Clutch kit
4. MSD digitial 6 plus
5. Nitrous kit, wet fogger
2. cross drill 2&3
3. shot peaned rods
7. A/c delete
12. AFPR
1. New Rad.
2. Jme cam
