wtf brake pad cutting into rotor??
Seized Brake Caliper
I guess I don't understand why you're (apparently?) more worried about the rotor groove and the squealing than the car's pulling to one side while braking. The latter is a serious safety issue. I'd fix the pulling first and worry about the other stuff second. I'm not sure the groove is a serious problem as long as it's not getting bigger (think slotted rotors).
Road debris kicked up when the tires roll over will sometimes get stuck between the pad and rotor and will scour the rotor. Same thing happened to me right after I did a brake job with new pads and rotors. Other than cosmetic eye-sour, functionally it doesn't seem to affect braking.
The guy rolls down the mountain over 120 km/h using only brakes to control the speed? And those brakes don't overheat?!?
After ten years of that, I hope he didn't run out of brakes at the bottom
