fuel pump relay?
Old 09-26-2007 | 10:52 AM
oaky's Avatar
oaky
3rd Gear
Default fuel pump relay?
Hi
I just came across your forum. Hope you don't mind me posting a question.
I'm having problems starting my S2. Sometimes it starts ok, others it turns over but doesn't fire. I've been told this is likely to be the fuel pump/dme relay. Does this sound right? And does anyone know how I can test this relay myself before I buy a new one?
Old 09-26-2007 | 11:12 AM
Spidey944's Avatar
Spidey944
Do a search on dme relay in the topic line. should find the procedure for using a jumper wire. Regardless, they are only 25 bucks or so, should ALWAYS have a spare with you. 90% of us do in our gloveboxes.
Old 09-26-2007 | 06:45 PM
Andial951's Avatar
Andial951
Legend Killer
go to http:www.clarks-garage.com/ and look under DME Relay in the Garagae Shop Manual
Quick Reply: fuel pump relay?
