Early odometer parts?
Old 09-25-2007 | 03:23 AM
porcho heat's Avatar
porcho heat
Default Early odometer parts?
I've heard that the parts for early odometers are no longer available? VDO wouldn't even take mine to repair it for 120 bucks a pop...
Anyone know of any sources for these parts?
Old 09-25-2007 | 05:21 AM
RC924's Avatar
RC924
What parts are you after?
The plastic gear is available from KLA Industries for $30.
Is it a red 17 tooth gear one?
I have a late 924 160Mph one that I believe is the same as early 944 for parts.
Roger
Old 09-25-2007 | 11:56 AM
xsboost90's Avatar
xsboost90
ive got a few old units laying around- what do you need?
Old 09-25-2007 | 01:12 PM
porcho heat
I believe I need the plastic gear, I'm not sure until I open it up though.
All I know is that I sent it to VDO during my swap and they 'fixed' it for 700 miles, then it broke again... I called and complained and they said it was because of the lack of parts.
Old 09-25-2007 | 01:16 PM
PowerTechParts's Avatar
PowerTechParts
Check Rennbay. Travis has everything for the ODO I believe.
Old 09-25-2007 | 01:24 PM
xsboost90's Avatar
xsboost90
early cars didnt have a gear problem as far as ive ever seen. Usually the pin that holds the odometer gears slides over and the gears come apart.
do a search on early speedometer repair- i did a big writeup a few years ago.
Old 09-25-2007 | 01:30 PM
porcho heat
Searched, Thanks Dan!
https://rennlist.com/forums/showthre...light=odometer
In case anyone else was wondering.
Quick Reply: Early odometer parts?
