AHH!
Ok well i fixed my electrical problems, (wire kept shorting and blowing fuse). but now, after i disconnected my battery and reconnected it, the headlights wont go up all the way. i tried messing with the manual ****, but it just cycles the headlights up and down. if i had a manual it would probably tell me how to adjust it but since i dont i need you guys to help!
my wiring issue was due to some aftermarket switch for a light that the joe-dope i bought it from put in. with no key in the car at all, i pop the hood and go to the manual ****. i then can either spin it clockwise or counter. when i spin it counter it will slightly raise, then it will go by itself and raise the lights all the way up and then close them. if i spin it clockwise it will no go past a certain point because the electrical mechanism dosnt allow it. now when i go to put them up with key in either position 2 or car on, they only go halfway up. when i turn the headlights off it then raises to full height then closes.
