project: turbocharging 944 N/A the proper way
Old 05-03-2011, 11:59 AM
  #151
AScholtes
AScholtes's Avatar
It should be a faster spooling setup than the /8
Old 05-03-2011, 12:51 PM
  #152
Voith
Voith's Avatar
What is the downside of /6?
Old 05-03-2011, 09:25 PM
  #153
AScholtes
AScholtes's Avatar
Max power potential...
Old 05-03-2011, 09:46 PM
  #154
black944 turbo
black944 turbo's Avatar
Most people prefer the 27/6 over the 8 due to spool. As mentioned max power is a bit lower, but from my understanding not much.
Old 05-04-2011, 05:56 AM
  #155
Voith
Voith's Avatar
So what is that in numbers? I would like to be in the 300~320whp range. Most probably I will use non stock downpipe and 4" exhaust.
I like fabspeed 4".. did they stop producing them? I don't find it on their web page..
Old 05-04-2011, 08:44 AM
  #156
AScholtes
AScholtes's Avatar
I think you can achieve that with the /6 without a problem. The major issue from my research is the compressor on the 26 running out of steam in the top end, the 27 doesnt seem to have that problem and you should be good to that HP level with the 27/6
Old 05-04-2011, 11:19 AM
  #157
Voith
Voith's Avatar
Thanks. I'll use that 27/6 than as it is.
What about compression ratios, if I go with custom pistons I can change the ratio to any desired level.
What compression should I go with if I choose to get new pistons? I was thinking somewhere between 8.0:1 and 8.5:1..
As I understand it, low compression ratio is good for high boost, but sluggish while off boost. If I get higher compression, off boost driveability will be better, but pistons will suffer when higher boost is used..
Is there any specific info gathered on that topic for 951?
Old 05-04-2011, 12:57 PM
  #158
AScholtes
AScholtes's Avatar
You have it. Most modern ways of thinking and designs in turbo engines use a higher CR and lower boost levels. It is better for driveability and with modern turbo designs, the turbos can stay in an efficiency range and be small and more responsive.
For me, I would go with a 9:1 or 9.5:1 setup and keep the boost levels low....
Of course there will be the argument of modern engine management, combustion chamber design and variable cam setups... so, it's not quite apples to apples... but it still has the same basic reasoning behind it..
Old 05-04-2011, 02:03 PM
  #159
Voith
Voith's Avatar
trouble is... I like boost.
Just found some lost pictures of my car while it was still in one piece
Old 05-04-2011, 05:57 PM
  #160
AScholtes
AScholtes's Avatar
I feel your sentiment on liking boost... but I like having torque as much
Old 05-16-2011, 07:34 AM
  #161
Voith
Voith's Avatar
Intake port corrections
Old 05-16-2011, 07:40 AM
  #162
carbongecko
carbongecko's Avatar
well it definetly is a project. thankfully for you there are parts for it in most junk yards what kind of weight are you expecting to save by doing this? also are you planning on using the turbos transmission i was reading in a diffrewnt thread that you will run into issues if you try to use the n/a's transmission.
@tifosiman: found both bottles
Old 05-16-2011, 08:00 AM
  #163
Voith
Voith's Avatar
I'll use AOR trans that I got with turbo. I will also upgrade to ABS and later offset with brakes off 89 turbo and original 944 billstein escort cup shocks and these rims (18x8" & 11")
I will also get rid of things that are not needed(rear wiper, electric headliht adjustments, washing and such nonsense), but plan on keeping burgundy interior with sport seats, and will reupholster everything.
Plan for this car is to get it as close as it gets to go-kart, but with sort of premium interior and stainless everything.. It should be a bit lighter than stock turbo.
As far as junkyards, there is not a single 944 on our junkyards. Unfortunately I have to order all parts from either usa or germany. Usually its far cheaper to order parts from usa than from germany, or (god forbid) our dealership.
Old 05-19-2011, 10:31 AM
  #164
Voith
Voith's Avatar
Got block back from the shop, timeserted and resurfaced for MLS gasket..
This is the most expensive shop ever.. 356€ for timeserting with my timeserts and resurfacing
Old 05-19-2011, 02:08 PM
  #165
Voith
Voith's Avatar
And thanks to Ideola, my ARP fasteners are here
Quick Reply: project: turbocharging 944 N/A the proper way
