UnderDash Modules Possibly Not Stock? [86 944 N/a]
Any idea what these modules are under the dash?? Which of these are supposed to be there and which are aftermarket additions by previous owners?
![](https://forums.pelicanparts.com/uploads11/underdash1188503346.jpg)
The black box on #1 says
HI-----SET-----LOW and is a little white dial. I suspect it's an aftermarket alarm of some sort and this is the volume or sensitivity dial.
![](http://www.theexitwound.com/images/messages/underdash2.jpg)
I have gutted out the aftermarket alarm junk from both 944s I've had, and I felt so good afterwards. They didn't work though, because I didn't have the remotes for them.
So I got the alarms untangled and exposed and no longer tied to the dash. They're still connected by a wire or two which goes it looks like through the firewall under the dash to the engine bay but I cannot tell because there's an enormous plastic guard that I can't get off. I'm experiencing starter issues and I want to eliminate all possibilities of what could be causing my woes. What should I do? CAn I just cut the wires and be done with it? I can't find them on the other side of the firewall though.
![](http://www.theexitwound.com/images/messages/alarm.jpg)
That big black square in the upper half of the last image is held in with 3 plastic bolt-like connectors. I can get two of them off, but of course there's a 3rd one way behind up in the back that i cannot get my fingers around, a socket on or anything. It's like a giant box that covers all of the wiring.
Thats the gaurd for below the fuse box. I have found that is much easier to install/un-install when you unbolt the fuse board and lift it up so the wires aren't all bunched up underneath.
I was able to get that last plastic bolt off with a long extension on the socket.
Okay, thanks a bunch guys. The fusebox did eventually pull UP far enough where I could disconnect the aftermarket alarms the previous owner installed. Whatever they were, their fuses were blown and/or broken, and some of the wires were previously clipped. Though it didn't fix my non-start issue, it feels good have them out of there.
