Questions about Konis
Old 08-28-2007, 02:32 PM
gtroth
gtroth's Avatar
-For the top nut, I used the "OEM-brand" 02 sensor tool from autozone (~$10). Worked great.
-Drilling the 14mm hole in the bottom of the strut mount was much more trouble than I expected (I didn't have a drill with a big enough chuck).
-Rears will be easy if the bolts aren't siezed like mine were.
-The length measurement listed on the Paragon instructions were wrong - I had to cut ~12mm more off so the strut would insert into the strut mount (there are little tabs on the shock that can not go into the mount). I think the measurement on the little instructions that come with the strut are correct.
Other than that, real easy.
Old 08-28-2007, 02:54 PM
J Silverman
J Silverman's Avatar
Originally Posted by tk's944
so you have to take the shock off the car to adjust it thats kinda dumb
There is no access to the top of the shock anywhere to make it externally adjustable so they had to do it that way.
Old 08-28-2007, 03:22 PM
black944 turbo
black944 turbo's Avatar
The fronts are not to bad, folow the instruction on paragons web site. i was a little nervous about cutting my struts up, but they turned out great and I am much happier now that it has been done. I also went with the adjustable ride height kit. Makes a great adition.
Old 08-28-2007, 03:34 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
Originally Posted by Todd157k
I get koni's at less than half off.. my company owns Koni. hehehe.
Group Buy?????
Old 08-28-2007, 03:45 PM
Todd157k
Todd157k's Avatar
Originally Posted by azbanks
Group Buy?????
We're allowed one set of 4 per year. Should I start taking names for next year? LOL.
Old 08-28-2007, 03:47 PM
WizPorsche944
WizPorsche944's Avatar
I couldnt find paragon's instructions.
Old 08-28-2007, 04:48 PM
Voith
Voith's Avatar
I replaced my suspension few months ago with 28 setting adjustible SPAX PSX krypton gas, and it is great. rear shocks have a little bolt on the bottom for adjusting, and adjusting all 4 sides takes some 5 minutes. Great stuff by SPAX imo.
they are allso shorter for 21mm
I allso sandblasted the struits and springs and powdercoated them:
biger versions of the pics:
http://www.moj-album.com/uredi/voith/8084992/?stran=1
Old 08-28-2007, 05:07 PM
JustinL
JustinL's Avatar
Originally Posted by GTSilver944
After taking the shock off the car, you take off the dust cover, push down a button, then twist it to one of three settings.
Just to clarify, you have to take the bump stop out and then compress the shock fully before turning the shaft to adjust it. It is really obvious how much slower the rebound gets when you adjust it. I wish it was as simple as a button
For the fronts, it's really a straightforward job. Make sure you have all your tools before hand like the 14mm drill bit, spring compressor, drain pan, etc.. After you get it done, take it for a drive and then retorque the bottom bolt and the upper nut. If you've been thinking about doing springs, its a good time to do that too.
Old 08-28-2007, 05:32 PM
GTSilver944
GTSilver944's Avatar
Hmmm... I didn't compress it all the way to adjust it, but it still seemed to change. I'll double check and mess with it again before my next autox.
Old 08-28-2007, 07:03 PM
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
The early 944 rear Koni has the buttom adjustment setup, the late 944 setup has to be fully compressed to adjust.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 08-28-2007, 08:08 PM
Aviator
Aviator's Avatar
Hmm, all good tips, keep em coming!
The UPS man is coming on friday, and saturday is the tentative date. I'll take a ton of pics so I can put everything back together again! For the 14mm drill, I'll probably use a bench press. It's good to have friends with big tools.
Got them from Paragon, and just the fronts for now, rears to come soon. I didn't buy new springs, I want to see if the stocks have any life left in them. But now I'm wondering if I should have. All I saw were the 1" lowering springs, I have a S2, for $198. Any other recommendations for springs?
Old 08-28-2007, 09:52 PM
black944 turbo
Paragon adjustable ride height kit with 200# here and love them. No noticeable understeer and seems to feel a bit better.
Old 08-28-2007, 10:23 PM
gtroth
gtroth's Avatar
http://web.archive.org/web/200412090...ession.com/kb/
Old 08-29-2007, 11:36 PM
WizPorsche944
Where in Pennsylvania are you aviator ? I may want to spectate this.
Quick Reply: Questions about Konis
