Still struggling with clutch removal
Thankfully the 944 is not a DD so I can leave it on the lift for days. The clutch fork retaining bolt broke so I drilled it out. I screwed an 8 mm bolt into the fork bolt and hammered it but it won't budge. Is this bolt often that difficult or maybe I didn't drill enough off the retaining bolt?
i think one method people use is putting a socket over the 8mm stud, and tightening a nut and washer against the socket which would be trapped between the washer and clutch housing, and the pin will give first.
I used a slide hammer since engine was on a stand :/
Use the socket method as apierce918 mentioned. It worked out great for me, Once you get the pin to move use a vicegrip and pull it out. You can also wiggle the clutch fork through the slave cylinder hole(makes it a little easier sometimes)
