Quick strut/spring install question
if the springs overshadow the threaded top portion of the damper shaft, when the shaft is fully extended, you will need a spring compressor, unless you have really really strong hangs
and i also woudnt try to "grab a little thread" either, make sure you can put the top hat on with full thread showing.
