Installing a radiator overflow reservoir question
I'm going to install an overflow reservoir tomorrow, I think. I assume there has to be a way to drain the fluid out of the radiator. I don't need to drain the whole thing. The fluid's only a couple of years old. Just get it down below the overflow reservoir. Is there any way to get the anti-freeze level down just low enough to install it?
Are you replacing the coolant tank? I finally broke down and bought a nice white one to replace the grotty yellow stained one. I undid the bolts, lifted the tank up, loosened the clamp for the hose, pulled it off and tied it up high as I could. Did not lose any coolant at all. Clamped the hose full of coolant to the underside of the new tank and bolted it back in. No air in system, no bleeding, no problem. Sure looks better with a white tank, if anyone wants a yellow tank for a track car, 20 bucks plus shipping from Canada and it's yours.
Mike
Mike
Mine's in the shame shape as yours. It's starting to crack it's so old. I'm worried about getting antifreeze on my engine. I did that on a previous car and got to smell it for awhile.
What's so hard about draining the coolant and putting fresh stuff back in? It's a good thing to replace the antifreeze every once and a while, and flush it sometimes as well.
Well I wasn't wanting to empty the radiator. The fluid in it is only a couple of years old. I just need to drop the level down low enough to install a new reservoir. And I am wondering if that's possible. I assume it is, just wanting to make sure. And I wasn't sure where the radiator plug is located.
Yeah might as well just drain it, they say you should every year but most people don't. I good flush can't hurt. I know what you mean about yellow reservoirs, the one on my old NA was pretty bad but luckily they're easy to remove.
