engine overheating...
1 Post
during idling and stop-and-go traffic on a warm day. The fans work, although they are noisy (rattle a bit). Can the fans be partially worn out? Does it make a big difference to upgrade from 3 blades to the 6 blades model?
I don't think it's the thermostat, because it cools down when I resume speed.
comments? thanks
comments? thanks
could be a plugged or covered radiator. thats what mine was. I upgraded to the late fans but Im not sure if they pull more air, or are just quieter. if the temps go down at speed id look at radiator...
first thing and the cheapest thing i would do is bleed the coolant, coolant bleeder screw is located on the upper radiator hose attachment. jack the car up, 12 mm wrench, fill up coolant, and burp it.
1 Post
Hey Man
Originally Posted by KuHL 951
No matter what you find, the 6-blade fan upgrade is worth every penny IMO.
Hey Man
Originally Posted by Luis de Prat
Agreed. Just be sure to reposition the coolant hoses or these fans will quickly eat them up.
Or buy the later hose that moves it further away from the fans.
