I have a 1983 944, i was just wondering what the offset is and the bolt pattern is for the erly 944's are?? i can't seem to find any info on this anywhere
You can fit larger offsets (higher than 23.3mm) with spacers. Smaller offsets will make the wheels stick out from the fender. The # you want to look for is after the "et". For instance, I just bought a set of Speedlines for the rear of my early offset turbo: 10JX18et25. Thats an 18" wheel 10" wide with an offset of 25. HTH.
