Perry 951 Dash LED's, Production Run #2
Old 09-04-2007, 01:06 PM
  #46
nize
nize's Avatar
Originally Posted by nize
can someone clarify if this LED installation disables the dimmer ability of the dash or does the dash dimmer still work like stock?
bump. can anyone answer this question ?
Old 09-04-2007, 01:08 PM
  #47
Techno Duck
Techno Duck's Avatar
I do not have Perry's kit but the FlamingEye LED's made by Darren in the UK. Not sure if he is still making them or not. The dimmer still does work, but the LED's do not dim very noticably. I would say in the area of 10-15% difference in brightness between max bright and full dim.
  #48
Randy_J
Randy_J's Avatar
Dimmer no longer works - bright all the time.
Old 09-04-2007, 01:21 PM
  #49
nize
nize's Avatar
thanks guys. any way to maintain the dimmer ability ?
Old 09-04-2007, 01:28 PM
  #50
UncleMaz
UncleMaz's Avatar
LED load equalizers often help. They are available in most chain auto parts stores.
Old 11-12-2007, 04:06 PM
  #51
TRDRacer
TRDRacer's Avatar
Does this include the instrument panel and the climate control?
Old 11-12-2007, 05:04 PM
  #52
reno808
reno808's Avatar
you can use a dimmer from a volkwagon. They use LEDS
Old 11-12-2007, 05:43 PM
  #53
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Perry, if you are still making these, put me down for a set, white please.
PS: Everyone, replacing the bulbs with LED's make it worse, if you use that 194 LED buld (whatever it is), it did not work out very well, the stock was brighter.
Old 11-12-2007, 06:13 PM
  #54
orcadigital
orcadigital's Avatar
When you say replacing with LED's is worse, I am confused? It seems to be the common method to brighten the dash in general?
Old 11-12-2007, 06:31 PM
  #55
VWaddict
VWaddict's Avatar
Yes.
Wire two LEDs in Series, to raise the total forward drop voltage. -Reduce the value of the series resistance slightly to compensate.
Keith
Old 11-12-2007, 06:57 PM
  #56
ausgeflippt951
ausgeflippt951's Avatar
I was under the impression that it was just the gauge cluster.
And speaking of which -- any progress on this front at all?
Old 07-19-2008, 07:00 PM
  #57
Toran
Toran's Avatar
Still not sure how to finish this climate control light project.
Was there any success in just replacing the bulbs with standard OEM ones or doing the LED upgrade.
Old 07-19-2008, 08:33 PM
  #58
Spidey944
Spidey944's Avatar
Looks like another one of those great projects....
Old 07-20-2008, 02:49 AM
  #59
Darwantae951
Darwantae951's Avatar
And? At least he didn't start a new thread and have it filled with "why didn't you search." He has a question, let him ask it.
Old 07-21-2008, 04:59 PM
  #60
Robby
Robby's Avatar
I have LEDs from NH SPeedo & the dimmer DEFINATELY STILL WORKS! I'm not sure how this got started, as I know others say their dimmer still works w/LEDs, although some have said it wont have as much range- mine has plenty of range- mine are too bright even on lowest setting, but I haven't played w/resistors yet.
Perry951- I'm interested- And I'm 100% definately, for sure, interested, if you can do clmiate control.
Quick Reply: Perry 951 Dash LED's, Production Run #2
