I'm looking at an engine out of an automatic and I have a 5 speed
Will the engine out of an 85.5 944 n/a automatic fit in my 87 944 stick shift with no problems. Will it bolt right up or is there some changes need so it will fit in my 87 944n/a such wire harness, dme and so on ?
Reason: typeo
Ok my 87 porsche 5 speed has everything in it. I'm removing the engine and putting in an 85.5 engine out of a 85.5 automatic. What all will i need from the 85.5 automatic so it can work in my 87 5 speed ?
Ok my 87 porsche 5 speed has everything in it. I'm removing the engine and putting in an 85.5 engine out of a 85.5 automatic. What all will i need from the 85.5 automatic so it can work in my 87 5 speed ? Such as will I need dme ,wire harness, release bearing, flywheel, pilot bearing and electronics or will everything in my 87 work ?
So the only changes needed is a pilot bearing ? or is there more I need to know before I buy this 85.5 automatic engine for my 87 5 speed. Thanks all tips welcome
