Sway Bars on early 944 (26/18)
Ok, on the front bar, like others have mentioned, the late bars attach differently on the aluminum arms than they do on the steel arms. What we usually do is use the early cars end bushing and hog it out to fit the late bar. Here's some diagrams to see what you're dealing with:
http://www.paragon-products.com/prod...arts-early.htm
http://www.paragon-products.com/prod...parts-late.htm
If you don't have a rear bar, you'll need:
http://www.paragon-products.com/prod...lt_sb-6910.htm
Plus some drop links. The factory drop links are crazy expensive so you'd be better off going with something like:
http://www.paragon-products.com/prod...roplinkkit.htm
Of course you'll need to bring a factory swaybar and bushings into the equation as well.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
