So what's the deal with wheels?
Old 06-27-2007, 07:34 PM
Catfood
Catfood's Avatar
Default So what's the deal with wheels?
Porsche put 15" rims on most of there 944s. Lots of people like to buy aftermarket rims and such, many times 16" or so. Ive even seen big old dubs on a 44.
So my question is what kind of advantages do rim size give you? what are the advantages to having bigger rims. Handling, acceleration? Do they degrade the performance?
If Porsche put 15s on them I'm sure thats the optimal size for a well rounded car, but if I put wider ones one will my handling go up? even if acceleration goes down.
Old 06-27-2007, 07:44 PM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
Don't be ascardt to use the "search" function, many people do and it saves them this embara....
This has been covered extensively.
theiceman
Team Owner
theiceman's Avatar
Received 1,115 Likes on 797 Posts
To maintain the same overall wheel diameter bigger wheels mean shorter tire sidewall. Shorter tire sidewalls are moe ridgid and resond much quicker to steering input and enhance handling remarkably., Side walls also have less flex and make for less " body roll" under high speed maneuvering.
Smaller wheels wich provide larger sidewalls enhance comfort at the expense of some handling. The larger sidewall flex allows it to ride over bumps and absorb some of the shock. Also helps if you hit a large pothoe. MAY not destroy your rim.
Porsche tries to pick the best compromise of handling and comfort.
Old 06-27-2007, 07:47 PM
billthe3
billthe3's Avatar
Larger wheel = larger tire, larger brakes, more brake cooling, stiffer sidewalls (because of lower size) producing a stiffer ride, looks
smaller wheel = less rotational weight, larger sidewalls for a softer ride, cheaper
Old 06-27-2007, 09:02 PM
Keithr726
Keithr726's Avatar
iceman hit it right on target. Now rims width is another story, but generally the bigger the better.
Old 06-27-2007, 09:05 PM
billthe3
billthe3's Avatar
Not for the price of tires.
Old 06-27-2007, 09:09 PM
Keithr726
Keithr726's Avatar
true, forgot that one.
Old 06-27-2007, 09:37 PM
Catfood
Catfood's Avatar
what about acceleration? how much speed do I lose by going from 15" to 16", I could care less about a smooth ride.
Old 06-27-2007, 09:43 PM
Keithr726
Keithr726's Avatar
You won't loose any speed, acceleration should be better but you won't be able to tell.
Old 06-27-2007, 09:48 PM
shiners780
shiners780's Avatar
Depends on the wheels.
My 17" Forgeline wheels w/ Toyo RA1 tires, compared to the stock 16" phonedials with the same tires, are the exact same overall diameter, lighter, have stiffer sidewalls, all while being wider. In this case, much to gain/nothing to lose.
Cost of tires is all part of the grin-factor. That's like thinking about what kind of gas mileage you're getting. Who cares?
Old 06-27-2007, 11:10 PM
gtroth
gtroth's Avatar
--seems like there are more tire choices these days for > 15" rims.
Old 06-27-2007, 11:45 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
Lord knows I haven't
Old 06-28-2007, 03:21 AM
Legoland951
Legoland951's Avatar
By going from 15" to 16" 225/50 for both sizes, I lost a lot of time on the track. Bigger does not mean better from the track point of view. I have seen someone go from 17 dot R tires to 18 full race (not the dot R compound tires) and actually lost time. There is also easier tire spin from a larger diameter wheel since there is not as much sidewall to absorb the launch or acceleration. Look at most race cars (F1, Indy, NHRA, etc) and you won't see tiny sidewalls with respect to wheel diameter for whatever the reason. Bigger diameter wheels are mostly for looks in my opinion.
Old 06-28-2007, 10:57 AM
Darwantae951
Darwantae951's Avatar
True, but doesn't Porsche use 18s on all their factory Cup cars? I'd have to think that there is some advantage to 18s over 17s, 16s, etc... I was reading an article about a Carrera 2.7 RS in excellence and they specifically noted that you could feel the flex in the body from the tires and it made them somewhat reluctant to push it in the corners (that and it was a $130,000 car). Maybe people just weren't used to the new behavior of the new wheels/tires and made mistakes?
-Darwin
Old 06-28-2007, 11:13 AM
JayP
JayP's Avatar
The reason F1 and NASCAR mandates small wheels is to keep cornering speeds low(ish) and limits brake sizes.
Quick Reply: So what's the deal with wheels?
