am i screwed here
06-27-2007 | 04:15 PM
am i screwed here
i dropped a reference sensor bolt into a hole next to it. looks like the bellhousing?
06-27-2007 | 04:18 PM
Take the bottom protection plate off of the bellhousing, hopefully the bolt will fall out.
06-27-2007 | 04:38 PM
Mine fell between the the flywheel and the block. Luckily all I had reassembled at the time was the clutch/PP. Hopefully yours will come out the bottom.
06-27-2007 | 05:14 PM
is the protection plate under the car?
06-27-2007 | 06:00 PM
It will probably fall out. I did this twice... Just spin the engine by hand with a wrench on the crank bolt until the little bolt works it way out.
06-27-2007 | 06:23 PM
all i have is the intake off now, does this mean i have to wrangle more stuff off it to spin the engine?
06-27-2007 | 06:31 PM
Whatever you do, don't push that clutch in. The last thing you want is to have that bolt wedge between the pressure plate and the flywheel.
06-27-2007 | 10:33 PM
Just take the plugs out. Use a 24mm socket, and turn while you wait to hear the bolt hit the ground....hopefullly!!!!
06-28-2007 | 10:46 AM
A lot of automotive /hardware store sell flexible magnet thingies for picking up dropped bolts and such, that might mork.
... er, I meant "work"
06-28-2007 | 02:20 PM
Could also take the starter off, then spin the motor to see if it drops out.
06-28-2007 | 08:37 PM
You are just so screwed -- give up now.
06-29-2007 | 07:44 PM
thats real inspiration, i took the protection plate off and its a real tight fit, doesnt look like a bolt is going to fall anywhere. Should i drop the starter?
06-29-2007 | 08:00 PM
RL Community TeamRennlist Member
Drop the starter. Take out the spark plugs. Turn the engine over with a 24mm socket on the front crankshaft pulley. Turn slowly until the bolt falls down and (hopefully) out through the starter opening.
And don't push the clutch pedal!
06-30-2007 | 07:33 PM
i got two starter bolts out.. are there more then that?
06-30-2007 | 07:44 PM
nope- just two big bolts that hold it on- make sure your batt is disconnected and slide that baby out of there w/ the wires on it .
